4 Pirelli Scorpion Winter tires 275/40R-21 only $200!
Trader history for Fusys (0)
Fusys
PA
2015 xc90
Perfect time to get amazing snow tires on the cheap! We are moving to Florida and won't be needing winter tires. These tires have only seen 4 months of use! Paid $1100 for these tires last fall. Drive with confidence and safety this winter on these high end snow tires. Well over 50% life remaining on tires.
$200 for 4 tires: 275/40R-21 PIRELLI SCORPION WINTER XL
We had them on our 2016 XC90 with 21" 10 spoke alloy wheels.
Tires are currently in Pittsburgh, Pa then Tampa, FL after July.
Buyer pays for shipping if needed.
Call or text 412-352-0005.
crewcabrob
NE
XC90 Inscription
Hi,
I may be interested in your tires. Can you confirm the size for me? As far as I know, there was not a 10 spoke 21" wheel in the US. There is an 8 spoke 21" wheel on the inscription that uses that size.
Any pics of the remaining tread depth?
Thanks,
Rob
crewcabrob
NE
XC90 Inscription
Thanks for checking on the size and tread depth.
Rob
Fusys
PA
2015 xc90
Hi Rob,
I'm attaching links to a couple of images.
I took the wording for the wheels right from the window sticker. I've seen quite a few of these designs in my area so I know it's pretty common. I do have the Inscription. Image attached.
The tread depth is 6mm total, and 3.5mm-4mm above the min wear marker. I attached an image of a ruler sitting on the min wear marker. The first mark from the edge of the plastic is 3mm so that's where the ruler starts counting.
Images:
https://drive.google.com/file/d/0B1wJYPbpmFZaVUQ1VTIycE96MzA/view?usp=sharing
https://drive.google.com/file/d/0B1wJYPbpmFZaeTlDOHRVSDl3Vms/view?usp=sharing
https://drive.google.com/file/d/0B1wJYPbpmFZaQmxpZXFzXzJPbEU/view?usp=sharing
crewcabrob
NE
XC90 Inscription
Hi Rob,
Images:
Thank you for sending the info and pictures. I'm in the process of convincing my wife I need these for my XC90. She doesn't think we get enough foul weather here for dedicated snow tires. She has never had a set, so its hard to guide her all the advantages.
I will be in touch soon.
Rob
Thread starter Similar threads Forum Replies Date
RL2016Rdesign Wheels, Tires, Suspension, Brakes & Chassis 5
