BRAKE PRESSURE SENSOR CODE , SLIGHT PULL ON BRAKE APPLICATION
Huntingtown
MD
2005 xc90 2.5L Turbo
Hi all, I am hoping someone can provide some insight to an issue I have with my 2005 2.5L auto xc90 the vehicle has DSHC, SKID CONTROL and ABS. I have a brake pressure switch code and the car has a slight pull to the right on initial brake application. The scan data indicates a small difference in pressure between front and rear brake pressure sensors. I see the master cylinder is designed for diagonal brake application. My question is, shouldn't the brake pressure sensor values be the same?
