Winter Wheels and Tires 2017 XC90 T8 AWD Hybrid
Anyone have suggestions?
I can't find any winter tires that are 275 35 22. Looks like I will need a whole new rim/tire set.
What have others done? Went down to 20''?
RonXC
FL
Are you referring to snow tires? 18" is probably the largest snow tires you'll find. Find some cheap wheels on tirerack and order them with the snow tires.
Mavi57
Belgium
2017 XC90
Went down to 19" (18 not possible for T8)
Extremely important is the weight capacity of the rim should be at least 815 kg
I mounted them with Good Years 235/55 ultragrip performance gen 1 SUV tyres.
crewcabrob
NE
XC90 Inscription
There are 21" snow tires in the correct size for the xc90, you can find them on Tirerack. They are XL rated, but I didn't look close enough to see if they will support the weight of the XC90.
Rob
NY
Tire Rack has winter snow tire and wheel packages up to 20"
